Hyperkey w/ Caps Lock - doesn't seem to register Hyperkey + other key combos
Trying to generate some keyboard shortcuts using Hyperkey as configured in BTT.
It seems to be set up correctly - have a "Caps Lock" shortcut set to be the Hyperkey. That being said, when trying to make other shortcuts based on the new Hyperkey shortcut, it only registers the CMD+OPT+SHIFT+CTRL, and will not register the next key press (ie. Caps Lock + 1 to generate some trigger).
What am I doing wrong here?
Take a look how I've configured it, hope it will help:
Configure Caps Lock as Hyper Key:
Usage of Caps Lock as Hyper Key:
Note that you need to press all 4 modifier keys + the next key (e.g. - 1) when recording a shortcut and not simply press Caps Lock (if I understand you are doing exactly this, right?).
Check the docs as well:
https://docs.folivora.ai/docs/1004_hyper_key.html
