It's currently only possible to exclude shift from hyper key.
However It would be great if excluding CMD instead would be possible.
At least I find it easier to use caps lock and cmd together instead of caps lock and shift.
you can create custom hyper keys, it's a bit complex to setup
Hi Andreas,
Got it sorted out, thanks for the advice!
Nice I was wondering how to do this!
The same day I got this work there was a new update available to BTT. I updated the app and now it crashes every time I am using the MEH key that I just set up.
