Hallo,
… some smaller issues with the formatting of the HUD text,
which appears to be always centered.
...and not sure whether pasted images in the HUD are supported at the moment (…at least they are shown in the GUI….)
thx,
Christian
Running:
BTT 3.9993 (2193) / Mac M1 Max OS 13.2 Beta (22D5038i)
BTT plugin Stream Deck option
Stream Deck Mobile (on iPad Air) latest version
unfortunately these are currently limitations on what swiftui can render (based on the Attributed String BTT uses).
So for now you'd need to use spaces to center. Images only work through the Icon configuration.
I think Apple might improve this further, as the general ability to render attributed strings has just been added in a recent macOS version
Ok, did not know that.
Thanks a lot,
Christian
