HUD - Stream deck connection lost
Hallo,
since alpha 4.047 a HUD (hardly readable in dark gray) is displayed briefly when the Stream deck connecttion is lost and needs to restart (I guess).
Is there a way to avoid the HUD display somehow ( or at least be able to format/color it )
Thx,
Christian
Running:
BTT 4.047 (2265) / Mac M1 Max OS 13.3
BTT plugin Stream Deck option
Stream Deck Mobile (on iPad Air)
I have changed it to be a system notification in the 4.048 alpha, also added a checkbox to the Stream Deck settings to completely disable the messages
