That's strange, it seems to work for me. Does it work as normal if you set it up with the Volume Up and Down actions?
Also does it work when you adjust it normally through the F5 and F6 keys? If not, check the top answer here: https://discussions.apple.com/thread/5075082
Both volume and brightness works like a charm. When it comes to keyboard light, it lags a lot and is not responsive. The "buttons" in the touch works so that is not the problem
HI,
im trying this gesture out but the zoom in/out on the Mac settings is conflicting. If I uncheck "zooming or out" from the Track settings then the gesture works wonderful. If I check it then when I rotate counterclockwise it zooms out too.
Any idea how can I go around this? I mean I want to have the "zoom in or out" in settings checked and have this new gesture work properly too.
Thanks.
Thanks so much for this, I wasn't sure if I was going to like it but I actually love it. It allows me to not take my hands off the trackpad and just feels so convenient.
Goodness, this was a great tip. The volume controls (rotate right and left) work great and I added FN button (rotate right and left) for brightness. Both work great. Thanks.
