Apologies if I'm missing a simple way to do this, I have a trigger to automatically open an application, then reconfigure it.
I would like to make sure that the trigger always opens the app within a specific monitor (always my MacBook monitor).
Mosaic allows me to do this, however was hoping to cut out an extra app in the workflow if possible.
Thanks for any help.
Don't you just love when you have posted a solution to the exact issue you are having in another post.
Doh!
