How to insert images?
@Andreas_Hegenberg I notice for the first time that I can't insert/paste images this way (below)? How should I do that? Thank you.
you can’t choose “ohne formatierung” in this case. Standard format should work for this
Mm, not sure what you mean, this?
This will delete the image.
strange, and adding it again doesn’t work? I’ll have a look
I can add it again, but after saving it is deleted again.
The goal is to replace a standard icon in the Finder, for example.
before
after
it should now save the images correctly again in the latest alpha.
However for your Finder use case the standard paste will not work. You can still achieve that with BTT, however you first need to convert your image to base64 text (e.g. via Image to Base64 | Base64 Encode | Base64 Converter | Base64) and then select this option:
I will improve the paste action with one of the next versions to make it easier to use.
