I am trying to write a transformer in JavaScript that takes a JSON, does some transformations and returns the manipulated JSON. I am not certain how to find the 2 variables
- text that is saved in clipboard currently
- or text that is selected by me with mouse.
Is there some documentation or a method to find these?
Basically, I want to run the following function on clipboard text / selected text
function prettifyJSON(jsonString) {
const object = JSON.parse(jsonString);
const prettifiedJSON = JSON.stringify(object, null, 2);
return prettifiedJSON;
