has anyone figured out how to do double tap and hold hyperkey to get it into meh key mode?
or have you found any other ways of using the same key for multiple things?
This is a general example of how to activate "something" with double tap and hold cmd.
And deactivate "something".
hi,
sorry for the late reply as i didn't realize my network went down and reply wasn't posted.
I tried this and I couldn't get my hyper key to act like a meh key when being double pressed and then held. Is there a way I can share my setting to see what I'm doing wrong?
Thank you
I'm also wondering how to make this work - I'm unable to make any key double tap and hold with this method even though it seems like it should work. Were you able to figure it out?
