How to define a minimum number of lines to scroll with "Smooth Scrolling" enabled?
I’m considering replacing Mos with BTT’s Smooth Scrolling, but I’ve noticed that each mouse wheel tick scrolls the page only a small amount. As a result, I have to scroll much more than I’d like to reach the desired part of the page.
I prefer to keep “Simulate Trackpad Scrolling” disabled. I’ve tried increasing the speed and acceleration to their maximum values, but this doesn’t change how much the page moves per wheel tick.
Is there a way to adjust how much each wheel tick scrolls the page?
Mos has Step, Speed, and Duration, which I have set to 35, 7, and 3.9 respectively. I suppose Step is what determines how much to scroll per wheel tick.
On a different note, enabling “Simulate Trackpad Scrolling” appears to ignore the “Inverse Scrolling” setting.
