I want to customize shape, size, position, background color, text color, emoji or SF symbol or png image- is there any way
Currently, it look like this
you can use the predefined action "show hud", it offers more options!
can i change its shape? from square to rectangle or circle?
no that is not possible, if you want full control you can set up some floating menu with the style you need and show that using the predefined action "show floating menu", then hide it again after some delay
is there a way so that the text not stick to bottom of hud overlay box and can be in vertically centre
how to get that?
select & cmd+c (or right-click => copy)
"BTTIsPureAction" : true,
"BTTPredefinedActionType" : 254,
"BTTPredefinedActionName" : "Show HUD Overlay",
"BTTHUDActionConfiguration" : "{"BTTIconConfigImageHeight":25,"BTTIconConfigIconType":1,"BTTActionHUDDisplayToUse":0,"BTTActionHUDOffsetX":0,"BTTIconConfigImage":null,"BTTActionHUDTitle":"","BTTIconConfigSFSymbolStyle":2,"BTTActionHUDDetail":"","BTTActionHUDDuration":1,"BTTIconConfigSFSymbolName":"link","BTTActionHUDHideWhenOtherHUDAppears":false,"BTTIconConfigIconColor1":"122.000000, 174.000005, 61.000000, 255.000000","BTTActionHUDBlur":true,"BTTActionHUDOffsetY":0,"BTTActionHUDHeight":50,"BTTActionHUDBackground":"0.000000, 0.000000, 0.000000, 0.000000","BTTActionHUDAttributedTitle":"{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fswiss\\fcharset0 ArialMT;}\n{\\colortbl;\\red255\\green255\\blue255;\\red0\\green0\\blue0;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c0\\c0\\c0;}\n\\pard\\tx560\\tx1120\\tx1680\\tx2240\\tx2800\\tx3360\\tx3920\\tx4480\\tx5040\\tx5600\\tx6160\\tx6720\\pardirnatural\\qc\\partightenfactor0\n\n\\f0\\fs36 \\cf2 \\uc0\\u9989 Copied Link}","BTTActionHUDSlideDirection":0,"BTTActionHUDBorderWidth":0,"BTTIconConfigIconColor2":null,"BTTIconConfigResizeImage":0,"BTTIconConfigImageWidth":10,"BTTActionHUDPosition":0,"BTTIconConfigIconColor3":null,"BTTActionHUDWidth":135}",
"BTTOrder" : 116
Ah it got confused because a sfsymbol name was entered, try to paste this:
"BTTHUDActionConfiguration" : "{\"BTTIconConfigImageHeight\":25,\"BTTIconConfigIconType\":1,\"BTTActionHUDDisplayToUse\":0,\"BTTActionHUDOffsetX\":0,\"BTTIconConfigImage\":null,\"BTTActionHUDTitle\":\"\",\"BTTIconConfigSFSymbolStyle\":2,\"BTTActionHUDDetail\":\"\",\"BTTActionHUDDuration\":1,\"BTTActionHUDHideWhenOtherHUDAppears\":false,\"BTTIconConfigIconColor1\":\"122.000000, 174.000005, 61.000000, 255.000000\",\"BTTActionHUDBlur\":true,\"BTTActionHUDOffsetY\":0,\"BTTActionHUDHeight\":50,\"BTTActionHUDBackground\":\"0.000000, 0.000000, 0.000000, 0.000000\",\"BTTActionHUDAttributedTitle\":\"{\\\\rtf1\\\\ansi\\\\ansicpg1252\\\\cocoartf2822\\n\\\\cocoatextscaling0\\\\cocoaplatform0{\\\\fonttbl\\\\f0\\\\fswiss\\\\fcharset0 ArialMT;}\\n{\\\\colortbl;\\\\red255\\\\green255\\\\blue255;\\\\red0\\\\green0\\\\blue0;}\\n{\\\\*\\\\expandedcolortbl;;\\\\cssrgb\\\\c0\\\\c0\\\\c0;}\\n\\\\pard\\\\tx560\\\\tx1120\\\\tx1680\\\\tx2240\\\\tx2800\\\\tx3360\\\\tx3920\\\\tx4480\\\\tx5040\\\\tx5600\\\\tx6160\\\\tx6720\\\\pardirnatural\\\\qc\\\\partightenfactor0\\n\\n\\\\f0\\\\fs36 \\\\cf2 \\\\uc0\\\\u9989 Copied Link}\",\"BTTActionHUDSlideDirection\":0,\"BTTActionHUDBorderWidth\":0,\"BTTIconConfigIconColor2\":null,\"BTTIconConfigResizeImage\":0,\"BTTIconConfigImageWidth\":10,\"BTTActionHUDPosition\":0,\"BTTIconConfigIconColor3\":null,\"BTTActionHUDWidth\":135}",
"BTTOrder" : 1
thanks!! made a copy Link extension replacement
Uses apple script (blocking) to copy current tab url to clipboard and a pill shaped HUD in top right
@Andreas_Hegenberg Is there a way to stop retriggering same action, if keys pressed twice or thrice, I want if previous action is going on- don’t trigger same again in meanwhile?
I have a keyboard shortcut to trigger applescript that to custom ocr with cleanshot x
turning on recursive trigger- make me 1 ocr at a time, but it keep popping (is it a bug?)
It would be amazing if there's a way to just simply change the HUD settings such as font size, box size, and box opacity and its a global setting that can be found under the BTT Settings menu.
Since the HUD feature already exist, creating a floating menu to get around the current HUD limitations might be too advance for basic users.
you can via the “show hud” action
OMG Yes! Amazing. Thank you! did not know that even existed.
