how to create blank preset
Hi all !!!
New to BTT. I'd like to know if it is possible to create a blank preset.
Starting with that empty preset, I'd like to learn how to create a "GROUP",
put something in it, view it and opening it in the touchbar.
Thanks !
Pace
You should see the progress on your TouchBar in life!
The Preset you see at the Beginning → PHoeNiX Preset - C3 update for Catalina (including a working AirPods widget!)
