The “move window to next monitor” works for normal app window but not to the BTT floating menu. The only usable option is right now there is a “move freely moving menu to current active screen”. But it is to move the floating menu to the monitor that has mouse pointer.
Will it be possible to achieve switch the floating menu to the “other” monitor, assuming i have macbook attaching to one external monitor?
I guess you could also use the predefined action "Update Floating Menu Properties", possibly followed by "Re-Position Floating Menu" to change the position of the menu
Thank you very much, this is exactly what i want, showing title bar make the floating menu like a normal app window and then “move window to next monitor” works. Great!
