I want to trigger different actions for:
Short press
Long Press
Long Release (Release after long press)
I have configured three triggers to show different HUDs in every case:
The HUDs for short press and long release are shown, but the HUD for long press is never shown.
If I disable the long release trigger, then I can see the HUDs of short press and long press.
So I wonder how to make the three triggers working at the same time.
Attached the three triggers:
exported_triggers.bttpreset (7.1 KB)
Frank1
December 4, 2025, 6:28pm
2
Mm, for me, all three triggers only work if “LONG PRESS” is also triggered when the key is released.
Are you able to trigger the "Long Press" HUD when the 3 triggers are enabled ?
Frank1
December 4, 2025, 6:39pm
4
Yes, but only if all three triggers are triggered when the key is released . That is not ideal.
There seems to be some issue, I think maybe related to a recent fix for a different issue. I'll check!
Actually it seems like this was never supported. It should now work in 5.801 alpha (uploading)!
Frank1
December 4, 2025, 7:53pm
7
I haven't tried that yet. But is it possible to trigger this
without also triggering this?
I'm probably misunderstanding something.
@jordikt (as far as I undestood) wanted to execute action A when pressing f19 only briefly, and wanted to execute actions B AND C when long pressing F19 (B) and releasing it afterwards (C)
This should now work in 5.801 but wasn't supported before.
Thanks @Andreas_Hegenberg !
Installed v 5.801, it is working perfect now
