How to Assign Specific Named Triggers to Stream Deck Plus Buttons?
I have a question about integrating my Stream Deck Plus with BTT. My goal is to keep using the Stream Deck Plus with its normal Stream Deck software, but also integrate BTT actions into it via the Elgato plugin.
Here’s my current setup:
•	I have created several **Named Triggers** in BTT.
•	In the Stream Deck software, I use the BTT plugin and assign those triggers to buttons.
•	However, when I try to select a specific trigger, Stream Deck always seems to execute only the **first trigger in the list**, regardless of the name I set in both BTT and the plugin.
What I would like to achieve is the ability to precisely decide which BTT trigger goes to which Stream Deck button (and at which position on my Stream Deck Plus).
Could you please let me know the correct way to configure this?
•	Do I need to create uniquely named triggers in a certain way?
•	Or is there another method to ensure the Stream Deck plugin reliably connects to the right Named Trigger in BTT?
Thanks a lot in advance for your help, and again for your amazing work on BetterTouchTool!
Best regards,
Can
  • Type of Mac: Apple M1 Pro
  • macOS version: Tahoe 26.0
  • BetterTouchTool version: 5.685
