How to adjust HUD icon alignment
How can I adjust the alignment of an SF Symbol inside the HUD background?
I'm using a HUD without text. It contains just a single SF Symbol icon. The symbol appears off-center, slightly lower, inside the HUD background.
How can I move it up to make it centered vertically? I get a similar off-center result if I type the symbol in the text field instead of the icon section. Thanks! @Andreas_Hegenberg
Screen Shot 2024-08-08 at 10.30.13
Screen Shot 2024-08-08 at 10.30.12
Screen Shot 2024-08-08 at 10.30.07
Here are my settings:
v4.654 alpha should fix the centering! (uploading now)
Thanks, works great!
