How does that work?
@Andreas_Hegenberg Can you please explain how these actions work?
They only work on Macbooks that have the accelerometer sensor (M1 Pro and higher)
Honestly more for playing around, not really useful :joy:. You can open the accelerometer live view to see the details
Ah, okay. Unfortunately, I don't have that yet. That's probably why I don't see that window either.
But the idea is that you could use, for example, a double-tap outside the trackpad as a trigger?
correct! (but it hard to find values that don't trigger accidentally too often)
The live view button is here:
Ich weiss, aber es zeigt sich kein Fenster. Vielleicht wegen Ventura?
Und die KI sagt:
"Nein, die MacBook-Pro-Modelle (oder Air) haben keinen Accelerometer, wie man ihn aus iPhone/iPad kennt."
Dann stimmt das wohl nicht :slight_smile:
