Good day! I'm trying to figure out how to do this. I want to be able to create this but can't figure it out. Thank you!
| Meeting Title | |
| Length | |
| Timing | |
| Attendees (Required) | |
| Attendees (Optional) | |
| Description |
| Meeting Title | |
| Length | |
| Timing | |
| Description |
Sorry, I don't understand what you are trying to do. Can you elaborate?
Good afternoon Andreas,
Sorry, and thank you for following up. Basically I'm trying to build a table using the keyboard shortcut feature and while it lets me paste in the table, when I hit save it loses the table formatting (but keeps the bolding).
I'd recommend to create the table with HTML, e.g.
<table>
<tr><td>Meeting Title</td><td></td></tr>
<tr><td>Length</td><td></td></tr>
<tr><td>Timing</td><td></td></tr>
<tr><td>Attendees (Required)</td><td></td></tr>
<tr><td>Attendees (Optional)</td><td></td></tr>
<tr><td>Description</td><td></td></tr>
</table>
Then use the "Paste Format: Interpret as HTML" option
You are AWESOME! Thank you!
