How do I swap Ctrl and Cmd keys?
Hello. I'm new to BetterTouchTool. I'd like to use it to globally swap the Ctrl and Cmd keys. I've seen the keyboard part of this app focuses in shortcuts more than just single keys, so, how can I achieve this key swapping?
Thank you!
sorry BetterTouchTool is not a good tool for key remappings. You should consider und Karabiner Elements app for that.
if you want to swap globally you can also do it in system preferences -> keyboard -> modifiers
Thanks for your reply!
I knew about the Modifier Keys window in System Preferences, but it changes both Ctrl and both Cmd keys at the same time. I want to swap only the left Cmd key with the left Ctrl key, then swap the Right Cmd key with the Right ALT key (NOT Ctrl), so that can't be achieved with the Modifier Keys window.
It's a pity that BetterTouchTool can't remap keys. If it did, I'd buy it in a heartbeat. I already use Karabiner-Elements, but it has some weird bug that swaps two keys (the >< key and the ºª\ key) without me having added such a rule. It's a bug that has been reported and happens to a whole bunch of people, but the developer of that tool doesn't seem to listen to us after years of having been reported, unfortunately.
So I hope you implement this functionality in some future version of BetterTouchTool.
Thank you!
+1 for this request
I have a Logitech Gaming keyboard that has the two keys backwards so I flip them globally in System Preferences. But now I'm trying to use zsh in Terminal.app and it can understand "meta" keys. I can set "Use Option as Meta" but that puts it in the wrong place compared to my emacs set up.
+1 for me as well
I already use it in teamviewer as it doesn't remap cmd+c . So wit BTT I just make ctrl+c out of it.
Would be great if I could do that with just cmd as well (to open new tabs)
A blast from the past, but a feature request here too. Looking for a better tool than Karabiner to remap my keys - it just doesn't support enough buttons.
Thanks for the great tool and yes, Karabiner is great for remaps. Unfortunately, Karabiner does not support remaps for a single application only within the UI and it is very clunky to work with when doing so in its JSON file to get such complex modifiers.
BTT could make Karabiner obsolete and improve our overall performance, when we can ditch Karabiner. A proper keymap feature is the last missing piece for the ultimate BTT.
Maybe this feature could be re-considered?
It looks like this feature was added to BTT starting with v4.988.
https://docs.folivora.ai/docs/1005_low_level_keyremap.html
correct, I recently added this!
Many thanks!
