I want to allow myself to use SHIFT+OPTION+/ in other applications with keyboard short cuts, but I need to kill the OS-level shortcut first which places a leading, upside down question mark ¿.
¿Any ideas?
¿Any ideas?
if you override it in BTT it will execute the action defined in BTT instead of the system action.
But that requires that I define some action in BTT. I just want the shortcut available for other applications. It'd be cool if there was a: "Bypass OS short-cut" action.
Unfortunately I don't think that is possible.
