Hot corners trigger
Hi!
I am a longtime user of BTT, and highly recommend it to any friend who buys a macbook :grinning:
I would love to have a "hot corners" trigger option - that I could pull the mouse to a certain corner, and actions would be triggered.
Something along the lines of the built-in option:
Is it possible?
Thank you!
go to "other triggers" and there to "corners of the screen" (or similar). There you will find beside the corners also the screen edges.
@Frank1 Thanks!
Only I can't find "other triggers"...
where is it located? :thinking:
Could you maybe provide a screenshot?
Try here :rofl: :joy:
Sorry, just kidding.
:flushed: wow...
:+1::+1:
:+1: :sunglasses:
