Create triggered actions in the "Named & Other Triggers" section of the form "Move Mouse To Top Left Corner" (or "Top Right", "Bottom Left", or "Bottom Right"). Then, disable BTT. The actions are still triggered!
Note that this occurs whether you use the menu bar to "Disable BTT For All Apps", "...For Active App", or if you select "Disable BetterTouchTool completely" for a given app in the "Global (App Specific Settings)" section of the BTT config.
When I want to disable hot corners, I have to quit BTT completely. This is quite cumbersome when it comes up for me.
Not related to input devices.
- Type of Mac: Mac mini (M1, 2020)
- macOS version: MacOS 11.5.2
- BetterTouchTool version: 3.579
I think I have posted about this before, but I cannot find the post in my account, so perhaps I misremember. Thank you for maintaining this absolutely essential software!
Best wishes,
ZS
