"Hide Global Triggers" not working in conditional activation group
Note: (I haven’t tested the latest alpha version)
I’d like to set up a conditional activation group to activate a set of stream deck buttons while Minecraft is focused. Since it’s not a standalone application, I’m using a conditional activation group which checks the process name is java (for some reason the window title is empty and I can’t use that, but thats ok).
It seems the “Hide Global Triggers” checkbox for the activation group has no effect. It works as intended for an app-specific group like “Finder” (hides all global trigger buttons), but for my “java” group it simply includes the buttons on the deck, the same thing that happens by leaving “Hide Global Triggers” unchecked.
Affected input device
Stream Deck XL
  • Type of Mac: mac mini M2 Pro
  • macOS version: 15.7.1
  • BetterTouchTool version: 6.017
