Hi guys,
Yesterday I updated BTT to the newest version (4.181 (2400)), and now I just noticed that I'm no longer able to hide and show the status bar icons, whether by double clicking on the status bar or by the keyboard shortcut what I chose for it. I think it might be a bug.
I tried already to restart BTT or log in and out and also hit the "Killall Dock" in Terminal to restart the bar, but nothing helped. So I think it might be a bug. I hope it will be fixed soon because I don't have access to the apps which are hidden.
Thanks
Ok, I've no idea what just happened, but now it works again.
Now I found the reason why it fails for me. I disabled BTT for InDesign for several years now because whenever it is enabled and I double-click on any page icon, it beeps like it won't let me do it. I already mentioned it and hoped for a solution, whether from Adobe or BTT, but unfortunately, there is still no solution.
Anyways, when I switch to InDesign and then back to another app, BTT is disabled for every app, and because of that, it won't let me show and hide the menu items.
And I have to enable it for all apps again.
So it seems it is a bug.
there was an issue in 4.177 to 4.181 that could sometimes cause BTT to get disabled and that also affected the enable behavior. This should be fixed in 4.182
Yeah, thanks. That fixed it.
