HID Devices - how can i remove them...
hello.
i have played around with a generic device.. and therefore i had to select it in the hid list. (see all connected hid devices...)
i was blown away, because i have now multiple keyboards..
as i write this post now, my keyboard is stucking.. its really strange and i think it can be linked to that list.
is there a possiblilty to remove those devices..
BTT just shows the names of your connected devices, to remove them you‘d disconnect them from your Mac
i dont have so many keyboards connected, just one internal of my macbook and one bluetooth keyboard.. hmmm
these are not separate keyboards, it’s just the different services offered by the same keyboard :wink:
In the screenshot I only see two keyboards, the internal one and the Magic Keyboard
ah okay. but is this normal? i mean can i check where all those services come from?
this is normal, no need to worry about it!
ok thank you!
