Help with transferring account and settings from one Mac to another
Hello everyone,
I have been using BTT for about a year on my personal MacBook and it's been such a useful tool. I got it initially to remove the ESC key I kept hitting but have found many other uses for it to speed up my productivity.
Anyway...I have just been given a new work MacBook with TouchBar and I really miss not having BTT installed. I was hoping to transfer my existing account along with all my current Touch Bar settings - is this even possible? Or do I need to purchase a new license and start again?
Appreciate your help.
Thanks,
Leon
You could :
  1. Export your preset(s)
  2. Sync your preferences with Dropbox or iCloud
Then import and resync on the new computer. Preference syncing is in beta, but presets exporting & importing has worked flawwlessly for me so far.
Or copy the folder:
~/Library/Application Support/BetterTouchTool
to the new Mac. All data is stored there.
Thanks both, appreciate your help!
Woah, didn't know about this. I should have done it for a few critical apps when upgrading/reinstalling Big Sur a few weeks ago. Will keep it in mind. Thank you!
