Hello,
I have a fairly specific question about the following setup and I’m wondering if your app can fix my problem.
At work we use MacBooks connected to a dock. Attached to this dock are two monitors plus one large touchscreen TV. One monitor and the touchscreen are mirrored, while the other monitor is set to extended mode. So the setup is basically A + B + B.
The touchscreen itself works fine, but only on the condition that the mouse cursor is on display B. If the cursor is still on display A, the touchscreen also registers input, but the mouse moves on display A instead — which you can’t see on the touchscreen, since it’s positioned a few meters away from the two monitors.
Is there a way to configure the mouse to automatically move to display B when the touchscreen is used? Or is there another solution to this problem?
Thanks in advance for thinking along!
