I'm new to BTT (and any real kind of automation) and I am a professional photographer. I'm moving all of my archives away from Apple Aperture and to a combination of Photo Mechanic Plus for cataloging & Capture One Pro 12 for pictures that need any serious editing. My goal is to automate enough repetitive tasks that I can make up for the time I will lose using two apps vs one before.
This is something that I worked on yesterday, with a button on the touchbar, it takes the selected files from Photo Mechanic and copies them to a specific folder on my desktop, then it opens Capture One, which imports the files and opens a new window with those pictures. This works to a degree, and that is based on how many pictures there are to copy and what delays I use.
I have two questions that I know about right now:
is there a way to have the completion of the action trigger the next action rather than trying to guess the delays needed to avoid breaking the workflow?
is there a way to extend the workflow to then delete the copied files because at that point they would be in Capture One, and i don't want to have to keep manually deleting these files before i run the next batch.
i understand if this is beyond the scope of BTT, but any help or pointers to another app that might then be controlled by BTT would be much appreciated.
