F1 pressed --> no action
F1 released before 0,31 seconds --> show a dialog box and stop the actions
F1 pressed more than 0,31 seconds --> send midi message "A" after 0,60 seconds and another midi message "B" after 0,80 seconds
F1 pressed more than 1,2 seconds should send a midi message "C" and cancel the sending of the midi message "B"
I have tried several things, but I am not getting a good result.
I think you need to set up something like this (below). The problem is that the actions are triggered when the key is released. That means you have to estimate the time, which probably doesn't work.
F1 released between 0,32 seconds and 1,2 seconds allows the sending of the midi message "A" and "B" but no midi message "C" is sent
F1 released after 1,2 seconds does nothing
So A shall be triggered after holding for 0.91seconds (0.31+0.6)
B shall be triggered after 1,11seconds (0.31+0.8) - or do you mean B should be triggered after 1.71seconds(0.31+0.6+0.8)?
"A" and "B" shall be triggered if F1 is pressed more than 0.31 seconds and released before 1,2 seconds: "A" would be triggered at 0,91 and ""B" would be triggered at 1,71
But if F1 is pressed more than 0,31 seconds and not released after 1,2 seconds, "A" should be triggered at 0,91, "B" should be canceled, and "C" should be sent at 1,2
This is currently indeed hard to, mainly because only one shortcut with the same key combo and a minimum press duration can exist.
I think I can remove that limitation for this special case easily. I'll check tomorrow.
I have configured one F1 press in the shortcuts section and several F1 releases in the key sequences section, using variables and time action sequences.
I explain it below, maybe somebody can find it useful.
@Andreas_Hegenberg I agree that is hard to do something like this now. Great if you can implement an easier way!
SHORTCUTS SECTION
F1 configured as TRIGGER ON KEY DOWN, all time values to zero, with three actions:
Two triggers with only one sequence (the release of the key) with all time values to zero. Both triggers have different advanced condition for the variable KeyPressed:
2.) The "Execute Action Sequence After Timeout" action got an option to immediately continue executing the remaining actions in the original action sequence. (This was how it was originally intended but some refactoring a long time ago changed this behavior)
One question: Why in the "Execute Action Sequence B After 1.40 Seconds" you put a "Cancel Timed Action Sequence B" in the list of actions? I don't understand that…
I wonder if there is a problem with the new checkbox to immediately continue executing the remaining actions in the original action sequence in the "Execute Action Sequence After Timeout" action.
When I imported the preset you posted, this checkbox was disabled in the Action Sequence A. I enabled it.
After that, I cut the trigger and pasted it in another place. Once pasted, the checkbox was disabled again.
You could also check this issue: very often the actions are hidden when I open the configuration of Action Sequences. Clicking outside the trigger and the trigger again fix it:
in your screen capture it looks like BTT is not the active window (your window buttons are not colored). Are you cmd + clicking? Or do you know what causes this?
No, that's because I have the graphite color as the contrast color in the system settings. This configuration makes everything gray, I feel more comfortable with that.
