I've crafted a shortcut that combines the transform and replace function with GPT and floating WebView. When activated, it takes the selected text uses a ChatGPT prompt and displays a popup window offering a more detailed explanation of the highlighted text. However, not all websites are compatible with this shortcut I created.
I was wondering if it would be feasible to utilize the most recently copied text instead of the highlighted text. Additionally, I'm curious if there's a way to grant BTT permission to access that particular website.
Thank you, and apologies if any part of this message is unclear.
Hi Andreas,
This is the script for the show "Floating Webview," but I think the problem is the transform/replace selection w/ ChatGPT can't access the selected text on that webpage. When I copy the text to a word or text editor first and then select it, it functions properly.
Thanks for all your help.
<!DOCTYPE html>
<html>
<head>
<style>
body {
background: white;
line-height: 2;
font-family: "Times New Roman", Times, serif;
font-size: 25px;
</style>
<script>
async function BTTInitialize() {
let result = await callBTT('get_clipboard_content', {});
window.document.getElementById("url").innerHTML = result;
try {
window.location = result;
} catch (e) {
console.log(e);
async function BTTWindowWillBecomeVisible() {
try {
} catch (e) {
console.log(e);
</script>
</head>
<body>
<p id="url"></p>
</body>
</html>
