Has anyone had any luck combining IFTTT with BTT? (I'm talking read/GET not write/POST)
So there's a few tutorials floating around to activate IFTTT through BTT (it just links to the WebHook). Has anyone had any luck finding a workaround to reading through IFTTT? I feel it would open up a world of possibilities for applications like Todoist, and others that sync with IFTTT but don't offer any Apple Script support.
I came across this:
But I'm not really sure what to do with it.
My coding is quite limited in skill.
I'll have a look at the IFTTT api to see whether that would be possible / what can be done. However I probably won't be able to add any deeper integration until end of July.
That's fine, there's far more on your plate than this!
Found a lengthy work around that might help anyone who pops in here.
Check my tutorial here.
