Issue Description:
When moving a window with key pressed, the window gets "stuck" in old screen (sort bounding off the edge of old screen) and the cursor gets displaced from its original location (moving into the new screen no longer on top of the window).
The issue does not happen when clicking the window by the title bar and dragging it w/o holding modifier key).
I'm using Function key as the modifier. It is not affected by changing modifier key.
This only happens when going from large screen to smaller screen. It appears to be related to virtually hitting the edges of the screen where the two monitors do not have a path (i.e. the top or lower part of the screen where small screen does not cover).
If I am moving by dragging title bar (i.e. not using BTT keyboard shortcut), when I hit a screen edge that does not have a path the window will stay still and not move and I can just drag the cursor down and it moves as soon as I get to a space that does have a path.
But when the same happens with BTT, the window starts bouncing (mostly up and down but sometimes off the edge) and acting erratically. And dragging down to where the path does exist does not cause the window to them move to the other screen. It seems to get in state where you have to let go and start over.
If I am careful to lower the cursor to offset the location of title bar relative to the place in the window where I clicked, to a place where there is a path, and then move it works ok. But it is often difficult to predict where that location is.
The issue appears to happen for some applications much more than others. i.e. Slack and Outlook for Mac. For these apps, it happens For BBEdit it behaves much better and rarely has this issue.
Settings:
Here is video demonstrating the behavior. In this video, the left screen is 1080x1920 and the right screen is 1920x1080. At the very end of this video I do not use the modifier key (just OS behavior) and it moves into the other window just fine as expected.
- Type of Mac: Macbook Pro 2019
- macOS version: Sequoia 15.5
- BetterTouchTool version: Version: 5.451 (2025060202)
- Input device: Happens with both Built-in trackpad and keyboard or external Apple keyboard and Apple trackpad
