I defined a keyboard shortcut series: first press esc, then move the window to another monitor, then enter full screen, in order to achieve move a full screen app to another monitor quickly. However, when i try this out, after esc, the animation will have a full screen app to normal size app, however the app has already been moved to another monitor, and the app-sized graph on the monitor will not disappear. The graph cannot be interacted with. Hide it and show it again, the graph can disappear.
I think it may not be a BetterTouchTool bug, maybe a MacOS bug... Still I would like to report that and see if there're any solution to that. Thank you!
Keyboard
- Type of Mac: Macbook Pro 13 inch, 2017 version, no touchbar version
- macOS version: Mojave (10.14)
- BetterTouchTool version: 2.645(954)
