I'm trying to get BTT to generate an INSERT key so that I can use that while remoting into Windows machines.
- If I use an external keyboard with a physical INSERT key on it, I'm able to use it properly when remoting to Windows machines
- If I try to record this key in BTT, BTT shows a "?" as the key it has recorded, and using it doesn't work when remoting to Windows machines
- If I use the MacBook keyboard equivalent of INSERT (which is fn-RETURN), BTT dutifully records it as "fn-RETURN". Unfortunately, this doesn't get sent across correctly to the Windows machine, so it's ignored
Ideally, INSERT would show up as an option in BTT under the "Keyboard Keys" actions section.
Has anyone figured out a way to make this work?
