four finger swipe up triggers default three finger swipe up
is there a way to separate the four finger swipe and the three finger swipe?
i configured a four finger swipe to a screen capture but when i do it, it also triggers the three finger swipe (mission control) so its pretty unusable. i saw a checkbox in the settings addressing this bug:
but when i check the box it does nothing. any help?
BTT does not work well if you use it in combination with the system default gestures. You need to configure all gestures in BTT that you use regularly.
i tried configuring the three finger swipe for mission control through BTT but then i dont have the smooth transition animation which i quite like
Unfortunately there is no way around that at the moment ;-(
