Click and Forceclick should have haptic feedback upon release, but it's doubled sometimes. I solved the problem for single finger by resetting SMC, but for 3 fingers it remains. I'll click once with 3 fingers with a single haptic feedback, then releasing causes two haptic feedbacks.
Macbook Trackpad
- Type of Mac: Macbook 13" 2015
- macOS version: 10.14.3 Mojave
- BetterTouchTool version: 2.716 (1026)
Earlier, single finger click and forceclick release both doubled. So I had 4 (four) haptic feedbacks upon full release. Solved with SMC reset.
When BTT is turned off, the problem disappears. I tried setting haptic feedback to "No Feedback" for both options in the screenshot, but it was still there.
