Force Click Notch Bar
Is there a listener for a force cllick on the notch bar? I see only tap, click, right-click.
I would love to have a force click available on the noth bar. Is this possible to implement?
Best wishes, Sam
you can set up a 1 finger force click in the trackpad section and set the trigger conditions:
The default "Trigger while mouse over menubar" would be easiest, but you could also use advanced trigger conditions for more flexibility
Thank you for the hint!
Correction / edit: I just found the menu for adding a feedback manually, so the first issue with missing haptic-feedback is no issue. So there is, contrary to what I wrote, just one small issue.
I have two minor issues with it though: First, the typical force-click haptic feedback is missing which feels very odd and then it collides (when I use notch bar only) with a single-click on the notch bar, which triggers a different action. So it is useable but … not for me, as it is right now. I will have to think of something else.
Still I now know one more functionality (conditional triggers) of BTT, which is great!
unfortunately the other issue can not really be solved - the problem is that a (system) click-down event happens before the force-click can even be recognized.
That is good to know and an interesting information. Thanks man. I am now using it as you suggested in the first place with the addition of a strong feedback, triggering cmd+q. Works perfectly!
Regarding the regular click being processed before the force click can be recognized:
I just moved to a new machine (Macbook Air M4 Sequoia; BTT 6.396) from Macbook Pro M1 Monterey (BTT 6.306) and on the old macthine this is not an issue. I use 3 finger click for opt+tab and 3 finger force click for cmd+w.
On the new machine infact this problem occured, resulting in (forefox) first switching tabs and then closing it.
On the old machine the tab switch only happened after releasing the 3 finger click…
I checked all settings.
What could cause the (unexpected, yet incredibly useful behaviour) on the older version/machine?
Thanks for support!
Semms to be fixed (force clicked processed on release avoiding double commands) since version 6.498 for me. Thanks!
