For generic Steam decks is there a post where we can submit info to get them added?
Hey good morning
HOTSPOTEKUSB HID DEMO:
Location ID: 0x01100000
Connection Type: Removable
Manufacturer: HOTSPOTEKUSB
Serial Number: 4250D2782842
Link Speed: 480 Mb/s
USB Vendor ID: 0x5548
USB Product ID: 0x1018
USB Product Version: 0x0002
on the back of the unit it says Basicolor/VSD inside hsv293s
Best create new threads for each device, yours is good.
You could try to add it and see whether it already works:
  1. quit BTT
  2. run this terminal command:
defaults write com.hegenberg.BetterTouchTool BTTMacroPadExtraDevices -array \
  "0x5548:0x1018:m18:Basicolor HSV293S"
  1. see whether you can bind a floating menu to it (item size might need to be adjusted from the templates)
If possible maybe post a picture of the device.
kind of works. Displays on the pad but the placement nor the action in BTT doesnt match the buttons on the unit. example and video below
thanks, that helps! I‘ll adjust the parameters for that device later today
thank you
I think I provided the wrong command for this device family. Can you try quitting BTT, then run these commands?
1:
defaults delete com.hegenberg.BetterTouchTool BTTMacroPadExtraDevices
2:
  "0x5548:0x1018:akp153v3:Basicolor HSV293S"
I think that did it thank you so much. One last question can we use gifs for the buttons?
Not right now. Some Macro Pads might support animated pictures but I have not yet looked into that.
Awesome I look forward to that in the future, I know this device does when I was using the VSD software.
Thank you again I really appreciate your dedication.
