Focused UI Element Inspector crashes
I'm trying to configure new normal mouse gesture with advanced condition, which restricts gesture scope to ony one window (Plant UML diagram preview window) of one application (IntelliJ IDEA)
To do so, I launch "Focused UI Element Inspector" from "Advanced Conditions..." menu of desired gesture config
Then I switch to IntelliJ IDEA app. and then activate PlantUML diagram preview window - and BTT crashes immediately
  • Keyboard, Normal Mouse
  • It seems that any device will be affected
  • Type of Mac: MacBook Pro 14-inch, 2021
  • macOS version: Version 13.4.1 (22F82)
  • BetterTouchTool version: 4.155 (2369)
btt-IDEA-PlantUML.crash (36.0 KB)
unfortunately it seems to crash inside one of the system accessibility functions. Maybe IntelliJ doesn't implement the API's correctly.
I'll check whether I can prevent it from crashing, but most likely it won't return useful data then.
