I was trying to edit the name of a trigger and realized I couldn't because the text field kept loosing focus every couple of seconds. In fact any selected BTT UI element will loose focus.
- Type of Mac: Macbook Pro 2021 16" M1 Max
- macOS version: 14.3.1
- BetterTouchTool version: 4.449
I‘d guess some trigger in BTT triggering something that causes the focus change? Have you checked the „recently used section“ for anything obvious?
Yes, sorry I had included my findings originally but wanted to do some more testing because there was something I found a little confusing.
But anyway, yes, it is indeed related to a Time-based trigger that runs every 3 seconds.
When I disabled that trigger, it takes a little while (about 10-20 seconds it seems), but the issue does stop. When I reenable to trigger the issue immediately comes back.
The trigger is an old one that has remained unchanged for years.
It simply runs this script:
set theSwitch to "/opt/homebrew/Cellar/switchaudio-osx/1.1.0/SwitchAudioSource"
set_string_variable "customVariable1" to do shell script theSwitch & " -c"
set variable to get_string_variable "customVariable1"
return variable
end tell
Should be fixed in 4.450 alpha! (uploading now)
Tested and solved! Thank you sir
