Fn toggle HUD variable
Hi there, I would like to set tap left middle on the trackpad to toggle Fn key in my Mac. However, I cannot make the HUD showing correct status of the Fn up or down. How should I configure it? P.S. I know little about code.
Could you please clarify what exactly is your use-case - what are you trying to achieve exactly.
