Floating View size keeps changing and Save Current Size doesn't work
@Andreas_Hegenberg
When I set the floating view size to something, and click save now, it increases the floating view size from what I set. And then the content of my webpage trims off. either from top or bottom.
Also clicking save now multiple times keep increasing the height of the floating view. What I want is that when I set the size, it doesn't change. And the page doesn't trim off. And, clicking save now make that size persistent.
I'm also not sure how the web item size affects this? Right now my floating view size is smaller and web item has a max height larger than floating view. I attached the preset below
bt
in some cases is has this weird white border around the view depending on the height∫tt
cl.bttpreset (9.4 KB)
