Floating Menus don't always respond to first click
Sorry if this has previously been mentioned. I searched and couldn't find anything but it's one of those things that might have been called so many things it's hard to search for.
This is very inconsistent, but often when I click on a floating menu button it does not respond. If I click again it will respnod but only on the 2nd or sometimes 3rd or 4th click. This is true across multiple floating menus used in different situations/alongside different apps. I have captured the behaviour on video but all it really shows is me clicking on a button and nothing happening then me clicking on the button again and it working.
It's extremely inconsistent. It happens enough that I'm sure I'm not imagining it, but attempting to reliably reproduce the issue has thus far proven useless.
The buttons worked perfectly for years but at some point in the last few months I noticed this behaviour start. I do not think it was tied directly to a BTT update, but it's entirely possible it was as I pay little attention to updates. Both BTT and macOS have been updated during that time, macOS several times.
Edit: Quick edit to add that the video I recorded visually shows mouse clicks and both the non-recognised and recognised click were recorded so the first click is definitely actually happening, it's not just that I'm not clicking and thinking I'm clicking or a hardware issue or anything like that.
MacBook trackpad. Not tried using any other input device.
n/a
  • Type of Mac: MacBook Pro M1
  • macOS version: 13.7.7 (22H722)
  • BetterTouchTool version: 5.566 (also happened on whatever previous version I had installed before updating today to confirm it was still happening on latest update)
I have similar issue, however this happens only on 1 floating menu button ("Standard Item"), which on press ("Actions Executed On Trigger (Button Release)") is executing a Real JavaScript. What are yours actions?
Mine are actually really simple. I have issues with my hands that make certain key combos difficult so I turned some into buttons I can just click. So the one I use most often (and thus see the issue with most often) is simply sending a 4 button keyboard shortcut to Affinity Photo. I have another that will simply send the contents of the clipboard to different apps.
So nothing overly complicated going on, and fairly different uses. It seems to be an issue with the floating menus themselves. If feels like it isn't being recognised as the topmost recipient of clicks sometimes, but I have no idea really.
Got you, so I my other floating menu buttons, are working just fine - like clicking should launch an app which is working 10 out of 10. So my issue I guess is somehow related to the script and maybe it is not the same issue like your I guess.
I guess it could be related to the macOS version @Jimmni could you share one of your simple menus? In general the floating menus set the "acceptsFirstMouse" property of the menus to true, but maybe some setting is interfering with that.
@xidiot if you want you can also share your script example that doesn't work
You can also send to andreas@folivora.ai if you don't want to post them publicly (to export right-click => export to file)
Hey. Sorry for the delay in responding. I'm not sure I exported it correctly, but here's one trigger that I have the issue with. It literally just passes a key combo. It worked fine for years until suddenly it started having this issue. I made no changes to it inbetween, but both macOS and BTT likely got updates.
Save.bttpreset (40.0 KB)
Here's a video showing it in action. Different buttons to the one I included above, but also just key combos being turned into buttons. You might need to go through it frame by frame as it's short, but you'll notice that the hover-over effect is registered as soon as the mouse enters the button. Then the click happens and is not registered. Hover effect stops. Second click is registered, button colour changes again. After that the button disappears but that's only because it changes focus to an app on another tab and if I'd let the video play longer you'd have seen it changing spaces to that app.
are you maybe using some other mouse related tools? I know that some users who have the "click through" option in the BetterMouse app active have encountered weird issues like this before.
No tools other than BetterTouchTool. I can't think of anything else I have running that might be getting in the way. BTT does all that kind of stuff for me. I'll try quitting the things I do have constantly running (things like Little Snitch, Oversight, BlockBlock) and see if any of them happen to be culprit, however unlikely.
it could also be a macOS 13 issue as the floating menus have been developed on >= 14 and I am only testing very little on older macOS versions.
I'll try this on my 13 machine soon.
Entirely possible. I've been on the same whole number macOS since floating menus were introduced and they were perfectly for a long time before this started happening, so if it is macOS 13 it's likely one of the point releases that triggered it. Just to make things more awkward.
It's a pretty minor issue, all-told, though. It's really not the end of the world if I have to click a few times. Thanks for looking into it, though!
Another idea:
One thing that was introduced at some point is that dragging is allowed anywhere in a floating menu by default. Now this is usually not a problem because clicks and drags are slightly different. However I definitely remember at least some users over the many years of working on BTT that had kind of a draggy-click-style and this would cause similar issues to the one described here :slight_smile:
Can you try to disable menu dragging for your floating menu and see whether that helps?
Will try, thanks! It needs natural usage to reliably test so I’ll see how things go over the new few days and let you know if it helps/doesn’t help. Thanks!
(I’ll note though that menu dragging was allowed before this issue started, but I can’t rule out my use of my trackpad changing at some point given the state of my hands.)
menu dragging in general was always allowed, but moving the menu by dragging on an item was added relatively recently
I haven’t tested enough to say with certainty yet, but it seems pretty likely that that was the problem as no more lost clicks since unchecking that box. :+1:
great, then I'll try to optimize the dragging behavior a bit to make it classify such "draggy" clicks correctly
I'm not sure if what I'll report has something to do with this, but it seems that some of mine "Standard item" only respond reliably on first click if I set the action under "Actions Executed On Button Press Down" and when set under "Actions Executed On Trigger (Button Release)" they require some strange clicks (sometimes it responds on double-click, sometime on the 1st click) on a specific places, on that item:
In "Recenty used" on each click on the item I see the following entry:
Here's the item:
    "BTTLastUpdatedAt" : 1759178948.5841751,
    "BTTTriggerType" : 773,
    "BTTTriggerTypeDescription" : "Standard Item",
    "BTTTriggerParentUUID" : "57CE4D24-5A30-456A-B1D0-87DB567F5562",
    "BTTTriggerClass" : "BTTTriggerTypeFloatingMenu",
    "BTTUUID" : "6F017412-E105-417C-B1A6-89D53D68ADEB",
    "BTTAdditionalConfiguration" : "Menu Item: Status message",
    "BTTOrder" : 7,
    "BTTTriggerName" : "Menu Item: Status message",
    "BTTMenuItemActions" : [
        "BTTLastUpdatedAt" : 1759178907.01529,
        "BTTTriggerParentUUID" : "6F017412-E105-417C-B1A6-89D53D68ADEB",
        "BTTIsPureAction" : true,
        "BTTUUID" : "FF9A5CBA-7029-4FEC-B90E-74F62481E327",
        "BTTPredefinedActionType" : 254,
        "BTTPredefinedActionName" : "Show HUD Overlay",
        "BTTHUDActionConfiguration" : "{\"BTTActionHUDBlur\":true,\"BTTActionHUDBackground\":\"0.000000, 0.000000, 0.000000, 0.000000\",\"BTTIconConfigImageHeight\":100,\"BTTActionHUDPosition\":0,\"BTTActionHUDDetail\":\"\",\"BTTActionHUDDuration\":0.90000000000000002,\"BTTActionHUDDisplayToUse\":0,\"BTTIconConfigImageWidth\":100,\"BTTActionHUDSlideDirection\":0,\"BTTActionHUDHideWhenOtherHUDAppears\":false,\"BTTActionHUDWidth\":220,\"BTTActionHUDAttributedTitle\":\"{\\\\rtf1\\\\ansi\\\\ansicpg1252\\\\cocoartf2822\\n\\\\cocoatextscaling0\\\\cocoaplatform0{\\\\fonttbl\\\\f0\\\\fswiss\\\\fcharset0 Helvetica-Bold;\\\\f1\\\\fswiss\\\\fcharset0 Helvetica;}\\n{\\\\colortbl;\\\\red255\\\\green255\\\\blue255;\\\\red0\\\\green0\\\\blue0;}\\n{\\\\*\\\\expandedcolortbl;;\\\\cssrgb\\\\c0\\\\c0\\\\c0\\\\c84706\\\\cname labelColor;}\\n\\\\pard\\\\tx560\\\\tx1120\\\\tx1680\\\\tx2240\\\\tx2800\\\\tx3360\\\\tx3920\\\\tx4480\\\\tx5040\\\\tx5600\\\\tx6160\\\\tx6720\\\\pardirnatural\\\\qc\\\\partightenfactor0\\n\\n\\\\f0\\\\b\\\\fs80 \\\\cf2 test\\n\\\\f1\\\\b0\\\\fs24 \\\\\\n\\\\pard\\\\tx560\\\\tx1120\\\\tx1680\\\\tx2240\\\\tx2800\\\\tx3360\\\\tx3920\\\\tx4480\\\\tx5040\\\\tx5600\\\\tx6160\\\\tx6720\\\\pardirnatural\\\\qc\\\\partightenfactor0\\n\\n\\\\fs48 \\\\cf2 test2}\",\"BTTActionHUDBorderWidth\":0,\"BTTActionHUDTitle\":\"\",\"BTTActionHUDHeight\":220}",
        "BTTOrder" : 2
    "BTTMenuConfig" : {
      "BTTMenuItemBorderColorHoverDark" : "255.000000, 255.000000, 255.000000, 255.000000",
      "BTTMenuItemVisibleWhileActive" : 1,
      "BTTMenuItemImageOffsetY" : 0,
      "BTTMenuItemIconType" : 1,
      "BTTMenuScriptUpdateInterval" : 4,
      "BTTMenuAttributedTextDark" : "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 Menlo-Regular;}\n{\\colortbl;\\red255\\green255\\blue255;\\red253\\green154\\blue45;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c100000\\c66667\\c22745;}\n\\pard\\tx560\\tx1120\\tx1680\\tx2240\\tx2800\\tx3360\\tx3920\\tx4480\\tx5040\\tx5600\\tx6160\\tx6720\\pardirnatural\\partightenfactor0\n\n\\f0\\fs22 \\cf2 menlo}",
      "BTTMenuItemBackgroundTypeDark" : 0,
      "BTTMenuItemImageChangeColorDark" : 1,
      "BTTMenuItemBackgroundColor" : "108.442, 96.000, 190.435, 166.991",
      "BTTMenuItemBorderWidth" : 0.5,
      "BTTMenuItemBorderWidthDark" : 0.5,
      "BTTMenuItemIconPresetPathDark" : "BTT_PRESET_PATH\/6F017412-E105-417C-B1A6-89D53D68ADEB-BTTMenuItemImageDark.png",
      "BTTMenuItemBackgroundColorDark" : "108.442, 96.000, 190.435, 166.991",
      "BTTMenuScriptAlwaysRunOnFirstLoad" : 1,
      "BTTMenuItemCornerRadius" : 0,
      "BTTMenuItemImageHeightDark" : 24,
      "BTTMenuItemResizeImage" : 2,
      "BTTMenuItemMinHeight" : 24,
      "BTTMenuItemBackgroundColorHoverDark" : "90, 90.000, 180, 166.991",
      "BTTMenuItemBorderColor" : "0.000000, 0.000000, 0.000000, 255.000000",
      "BTTMenuHoverEndAnimationDuration" : 0.14999999999999999,
      "BTTMenuUseStyleForSubmenu" : 1,
      "BTTMenuItemImageOffsetYDark" : 0,
      "BTTMenuItemIconTypeDark" : 1,
      "BTTMenuItemScriptActive" : 1,
      "BTTMenuItemIconPresetPath" : "BTT_PRESET_PATH\/6F017412-E105-417C-B1A6-89D53D68ADEB-BTTMenuItemImage.png",
      "BTTMenuItemBlurredBackgroundDark" : 1,
      "BTTMenuItemBlurredBackground" : 1,
      "BTTMenuElementTooltip" : "Open YouTube Favourites in Firefox",
      "BTTMenuScriptSettings" : {
        "BTTScriptFunctionToCall" : "itemScript",
        "BTTJavaScriptUseIsolatedContext" : false,
        "BTTScriptType" : 3,
        "BTTAppleScriptString" : "async function itemScript(itemUUID) {\n\n    let status_message = await get_string_variable({variableName: \"custom_var_result_from_add_video_to_playlist\"});\n\n \/\/    await set_persistent_string_variable({variableName: \"custom_var_status_message\", to: video_id})\n\t\/\/ console.log('video_id', video_id);\n\treturn status_message;\n}\n",
        "BTTScriptExternalPath" : "\/Users\/myuser\/Library\/CloudStorage\/OneDrive-\/Documents\/btt\/scripts\/youtube_status_message_item.js",
        "changedFile" : "E60820BA-D38F-47B1-BE1D-83E4EF8F6317",
        "BTTAppleScriptUsePath" : false,
        "BTTScriptLocation" : 3
      "BTTMenuItemBackgroundType" : 0,
      "BTTMenuItemBorderColorDark" : "255.000000, 170.000005, 58.000000, 255.000000",
      "BTTMenuItemResizeImageDark" : 2,
      "BTTMenuItemBackgroundColorHover" : "90, 90.000, 180, 166.991",
      "BTTMenuItemShowIdentifierAsTooltip" : 2,
      "BTTMenuItemIconColor1Dark" : "255.000000, 170.000005, 58.000000, 255.000000",
      "BTTMenuScriptAlwaysRunOnAppear" : 1,
      "BTTMenuItemVisibleWhileInactive" : 1,
      "BTTMenuItemCornerRadiusDark" : 0,
      "BTTMenuItemMaxHeight" : 24,
      "BTTMenuAttributedText" : "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red0\\green0\\blue0;}\n{\\*\\expandedcolortbl;;\\csgray\\c0;}\n\\deftab720\n\\pard\\pardeftab720\\partightenfactor0\n\n\\f0\\fs22 \\cf2 \\expnd0\\expndtw0\\kerning0\nmenlo}",
      "BTTMenuHoverStartAnimationDuration" : 0.14999999999999999,
      "BTTMenuSizingBehavior" : 3,
      "BTTMenuItemMinWidth" : 100,
      "BTTMenuItemMaxWidth" : 200,
      "BTTMenuItemImageWidthDark" : 24,
      "BTTMenuTextMinimumScaleFactor" : 0.29999999999999999,
      "BTTMenuAppearanceStyle" : 0,
      "BTTLastChangeUUID" : "8AFFBD87-124C-49FB-9659-BB99725B3EF1",
      "BTTMenuElementIdentifier" : "Status message",
      "BTTMenuItemIconColor1" : "255.000000, 255.000000, 255.000000, 255.000000",
      "BTTMenuAlwaysUseLightMode" : 0
    "BTTMenuAvailability" : 0,
    "BTTMenuName" : "Status message",
    "BTTGestureNotes" : "Standard Item"
and here's part of menu's config:
{"BTTMenuDisableDrag":1,"BTTMenuCategoryZIndex":1,"BTTMenuElementIdentifier":"FirstFloatingMenu","BTTMenuTextMinimumScaleFactor":0.29999999999999999,"BTTMenuWindowLevel":3,"BTTMenuAlwaysUseLightMode":1,"BTTMenuBringToFrontOnHover":0,"BTTMenuKeepCached":0}
I've just tested with another "Standard item", which have action on right click and it was working previously, but on Version: 5.674 (2025092905) it doesn't:
    "BTTLastUpdatedAt" : 1759177481.8013911,
    "BTTUUID" : "062F7C22-76AB-49A5-A6A0-D84E5FD5CA7C",
    "BTTAdditionalConfiguration" : "Menu Item: NowPlaying",
    "BTTOrder" : 3,
    "BTTTriggerName" : "Menu Item: NowPlayingWorking",
        "BTTLastUpdatedAt" : 1731599213.0495639,
        "BTTTriggerParentUUID" : "062F7C22-76AB-49A5-A6A0-D84E5FD5CA7C",
        "BTTUUID" : "9DD2BB85-FF9D-4788-B20B-8F63E0AF1080",
        "BTTPredefinedActionType" : 23,
        "BTTPredefinedActionName" : "Play or Pause",
        "BTTOrder" : 135
        "BTTActionCategory" : 6,
        "BTTLastUpdatedAt" : 1756477381.039782,
        "BTTUUID" : "FE9E7A4C-605C-4C21-A446-2C218E8C8E07",
        "BTTPredefinedActionType" : 195,
        "BTTPredefinedActionName" : "Run Apple Script (async in background)",
        "BTTAdditionalActionData" : {
          "BTTMenuCategoryItemIcon" : false,
          "BTTMenuCategoryPosition" : false,
          "SelectedAction" : 195,
          "BTTMenuCategoryItemBehavior" : false,
          "BTTMenuCategorySpacing" : false,
          "BTTMenuCategoryItemVisibility" : false,
          "BTTMenuCategoryShadow" : false,
          "BTTScriptType" : 0,
          "BTTMenuCategoryBackground" : false,
          "BTTMenuCategoryModifiers" : false,
          "BTTMenuCategoryResizeOnHover" : false,
          "BTTAppleScriptRunInBackground" : true,
          "BTTAIScriptType" : 3,
          "BTTMenuCategoryZIndex" : false,
          "BTTMenuCategoryItemSizing" : false,
          "BTTMenuCategorySize" : false,
          "BTTMenuCategoryOnlyShowIf" : false,
          "BTTAppleScriptString" : "on itemScript(itemUUID)\n    tell application \"BetterTouchTool\"\n        set songTitle_clipboard to get_string_variable \"BTTNowPlayingInfoTitle\"\n        set songArtist_clipboard to get_string_variable \"BTTNowPlayingInfoArtist\"\n    end tell\n\n    set combinedInfo_clipboard to songArtist_clipboard & \" | \" & songTitle_clipboard\n\n    -- copy to clipboard\n    set the clipboard to combinedInfo_clipboard\n\n    return combinedInfo_clipboard\nend itemScript\n",
          "BTTMenuCategoryMenuVisibility" : false,
          "BTTScriptLocation" : 0,
          "BTTMenuCategoryMenuOpacity" : false,
          "BTTMenuCategoryBorder" : false,
          "BTTMenuCategoryItemSpacing" : false
        "BTTInlineAppleScript" : "on itemScript(itemUUID)\n    tell application \"BetterTouchTool\"\n        set songTitle_clipboard to get_string_variable \"BTTNowPlayingInfoTitle\"\n        set songArtist_clipboard to get_string_variable \"BTTNowPlayingInfoArtist\"\n    end tell\n\n    set combinedInfo_clipboard to songArtist_clipboard & \" | \" & songTitle_clipboard\n\n    -- copy to clipboard\n    set the clipboard to combinedInfo_clipboard\n\n    return combinedInfo_clipboard\nend itemScript\n",
        "BTTOrder" : 276
    "BTTMenuConfig" : {
      "BTTMenuScriptUpdateInterval" : 8,
      "BTTMenuAttributedTextDark" : "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red253\\green154\\blue45;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c100000\\c66667\\c22745;}\n\\pard\\tx560\\tx1120\\tx1680\\tx2240\\tx2800\\tx3360\\tx3920\\tx4480\\tx5040\\tx5600\\tx6160\\tx6720\\pardirnatural\\partightenfactor0\n\n\\f0\\fs22 \\cf2 menlo}",
      "BTTMenuItemImageWidth" : 24,
      "BTTMenuItemShadowEnabledDark" : 0,
      "BTTMenuItemShadowEnabled" : 1,
      "BTTMenuScriptRunOnMenuHover" : 0,
      "BTTMenuItemImageHeight" : 24,
      "BTTMenuElementTooltip" : "Play\/Pause",
      "BTTMenuItemImage" : "TU0AKgAAQAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAA8AAAAbQAAAIQAAACWAAAAmQAAAKcAAACqAAAAuAAAALsAAADJAAAAzAAAANoAAADdAAAA6AAAAO4AAADuAAAA7gAAAO4AAADuAAAA7gAAAPkAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAPkAAADuAAAA7gAAAO4AAADuAAAA7gAAAO4AAADoAAAA3QAAANkAAADMAAAAyQAAALsAAAC4AAAAqgAAAKcAAACZAAAAlgAAAIQAAABtAAAAOwAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwAAAGkAAADkAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADkAAAAagAAAAMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEgAAAMQAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADFAAAAEwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADgAAANMAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAANUAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAKoAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAArAAAAAAAAAAAAAAAAAAAAEYAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAABGAAAAAAAAAAAAAAC\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAwgAAAAAAAAAUAAAA\/QAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP4AAAAZAAAAVwAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAWQAAAHcAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAHkAAACMAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAACPAAAAmwAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAPYAAAD0AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAngAAAKkAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAIQAAAL8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAKkAAAC2AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAABAAAAZgAAAPUAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAC2AAAAwwAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAAAAAAAAAAAAAAAAApAAAAygAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAwgAAANAAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAB3AAAA+AAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAM8AAADdAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAADNAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADbAAAA5wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgAAAIQAAAD7AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA5gAAAOwAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALwAAANAAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAOkAAADwAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAAiAAAAPwAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADsAAAA8wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA5AAAA2QAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA8AAAAPcAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAAACIAAAA\/QAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAPMAAAD6AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADwAAADbAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD3AAAA\/QAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADgAAAJwAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA+gAAAP4AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgAAACxAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAPoAAAD6AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFUAAADsAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD2AAAA9wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFQAAAKwAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA8gAAAPMAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAASwAAAOYAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAO4AAADvAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPAAAAmQAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADrAAAA7AAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABHAAAA4wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA5wAAAOcAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4AAACbAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAOMAAADdAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADwAAADbAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADYAAAA0AAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAAAAAAAAAAAAAAAAAAAAAACQAAAIgAAAD9AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAywAAAMQAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADfAAAAAAAAAAAAAAAAAAAAOAAAANgAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAL8AAAC3AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA3wAAAAAAAAAIAAAAiAAAAPwAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAACyAAAAqgAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAN8AAAAuAAAAzwAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAApgAAAJ0AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD5AAAA+wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAJoAAACOAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAACLAAAAeAAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAcwAAAFgAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAFMAAAAUAAAA\/QAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAPwAAAASAAAAAAAAAL4AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAC5AAAAAAAAAAAAAABDAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAPgAAAAAAAAAAAAAAAAAAAKMAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAnwAAAAAAAAAAAAAAAAAAAAAAAAANAAAAzwAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAzAAAAAsAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA8AAAC9AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAAuQAAAA0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAGIAAADdAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADbAAAAXgAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADUAAABkAAAAgAAAAIkAAACZAAAAmgAAAKoAAACqAAAAuwAAALsAAADMAAAAzAAAAN0AAADdAAAA4wAAAO4AAADuAAAA7gAAAO4AAADuAAAA7gAAAPYAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD8AAAA7gAAAO4AAADuAAAA7gAAAO4AAADuAAAA7gAAAOMAAADdAAAA0QAAAMwAAAC\/AAAAuwAAAK0AAACqAAAAmwAAAJkAAACJAAAAgAAAAGMAAAAzAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABIBAAADAAAAAQBAAAABAQADAAAAAQBAAAABAgADAAAABAAAQPYBAwADAAAAAQABAAABBgADAAAAAQACAAABCgADAAAAAQABAAABEQAEAAAAAQAAAAgBEgADAAAAAQABAAABFQADAAAAAQAEAAABFgADAAAAAQBAAAABFwAEAAAAAQAAQAABGgAFAAAAAQAAQOYBGwAFAAAAAQAAQO4BHAADAAAAAQABAAABKAADAAAAAQACAAABUgADAAAAAQACAAABUwADAAAABAAAQP6HcwAHAAAMSAAAQQYAAAAAAAAADAAAAAEAAAAMAAAAAQAIAAgACAAIAAEAAQABAAEAAAxITGlubwIQAABtbnRyUkdCIFhZWiAHzgACAAkABgAxAABhY3NwTVNGVAAAAABJRUMgc1JHQgAAAAAAAAAAAAAAAAAA9tYAAQAAAADTLUhQICAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFjcHJ0AAABUAAAADNkZXNjAAABhAAAAGx3dHB0AAAB8AAAABRia3B0AAACBAAAABRyWFlaAAACGAAAABRnWFlaAAACLAAAABRiWFlaAAACQAAAABRkbW5kAAACVAAAAHBkbWRkAAACxAAAAIh2dWVkAAADTAAAAIZ2aWV3AAAD1AAAACRsdW1pAAAD+AAAABRtZWFzAAAEDAAAACR0ZWNoAAAEMAAAAAxyVFJDAAAEPAAACAxnVFJDAAAEPAAACAxiVFJDAAAEPAAACAx0ZXh0AAAAAENvcHlyaWdodCAoYykgMTk5OCBIZXdsZXR0LVBhY2thcmQgQ29tcGFueQAAZGVzYwAAAAAAAAASc1JHQiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAABJzUkdCIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAWFlaIAAAAAAAAPNRAAEAAAABFsxYWVogAAAAAAAAAAAAAAAAAAAAAFhZWiAAAAAAAABvogAAOPUAAAOQWFlaIAAAAAAAAGKZAAC3hQAAGNpYWVogAAAAAAAAJKAAAA+EAAC2z2Rlc2MAAAAAAAAAFklFQyBodHRwOi8vd3d3LmllYy5jaAAAAAAAAAAAAAAAFklFQyBodHRwOi8vd3d3LmllYy5jaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABkZXNjAAAAAAAAAC5JRUMgNjE5NjYtMi4xIERlZmF1bHQgUkdCIGNvbG91ciBzcGFjZSAtIHNSR0IAAAAAAAAAAAAAAC5JRUMgNjE5NjYtMi4xIERlZmF1bHQgUkdCIGNvbG91ciBzcGFjZSAtIHNSR0IAAAAAAAAAAAAAAAAAAAAAAAAAAAAAZGVzYwAAAAAAAAAsUmVmZXJlbmNlIFZpZXdpbmcgQ29uZGl0aW9uIGluIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAALFJlZmVyZW5jZSBWaWV3aW5nIENvbmRpdGlvbiBpbiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHZpZXcAAAAAABOk\/gAUXy4AEM8UAAPtzAAEEwsAA1yeAAAAAVhZWiAAAAAAAEwJVgBQAAAAVx\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\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\/AkHyRNJHwkqyTaJQklOCVoJZclxyX3JicmVyaHJrcm6CcYJ0kneierJ9woDSg\/KHEooijUKQYpOClrKZ0p0CoCKjUqaCqbKs8rAis2K2krnSvRLAUsOSxuLKIs1y0MLUEtdi2rLeEuFi5MLoIuty7uLyQvWi+RL8cv\/jA1MGwwpDDbMRIxSjGCMbox8jIqMmMymzLUMw0zRjN\/M7gz8TQrNGU0njTYNRM1TTWHNcI1\/TY3NnI2rjbpNyQ3YDecN9c4FDhQOIw4yDkFOUI5fzm8Ofk6Njp0OrI67zstO2s7qjvoPCc8ZTykPOM9Ij1hPaE94D4gPmA+oD7gPyE\/YT+iP+JAI0BkQKZA50EpQWpBrEHuQjBCckK1QvdDOkN9Q8BEA0RHRIpEzkUSRVVFmkXeRiJGZ0arRvBHNUd7R8BIBUhLSJFI10kdSWNJqUnwSjdKfUrESwxLU0uaS+JMKkxyTLpNAk1KTZNN3E4lTm5Ot08AT0lPk0\/dUCdQcVC7UQZRUFGbUeZSMVJ8UsdTE1NfU6pT9lRCVI9U21UoVXVVwlYPVlxWqVb3V0RXklfgWC9YfVjLWRpZaVm4WgdaVlqmWvVbRVuVW+VcNVyGXNZdJ114XcleGl5sXr1fD19hX7NgBWBXYKpg\/GFPYaJh9WJJYpxi8GNDY5dj62RAZJRk6WU9ZZJl52Y9ZpJm6Gc9Z5Nn6Wg\/aJZo7GlDaZpp8WpIap9q92tPa6dr\/2xXbK9tCG1gbbluEm5rbsRvHm94b9FwK3CGcOBxOnGVcfByS3KmcwFzXXO4dBR0cHTMdSh1hXXhdj52m3b4d1Z3s3gReG54zHkqeYl553pGeqV7BHtje8J8IXyBfOF9QX2hfgF+Yn7CfyN\/hH\/lgEeAqIEKgWuBzYIwgpKC9INXg7qEHYSAhOOFR4Wrhg6GcobXhzuHn4gEiGmIzokziZmJ\/opkisqLMIuWi\/yMY4zKjTGNmI3\/jmaOzo82j56QBpBukNaRP5GokhGSepLjk02TtpQglIqU9JVflcmWNJaflwqXdZfgmEyYuJkkmZCZ\/JpomtWbQpuvnByciZz3nWSd0p5Anq6fHZ+Ln\/qgaaDYoUehtqImopajBqN2o+akVqTHpTilqaYapoum\/adup+CoUqjEqTepqaocqo+rAqt1q+msXKzQrUStuK4trqGvFq+LsACwdbDqsWCx1rJLssKzOLOutCW0nLUTtYq2AbZ5tvC3aLfguFm40blKucK6O7q1uy67p7whvJu9Fb2Pvgq+hL7\/v3q\/9cBwwOzBZ8Hjwl\/C28NYw9TEUcTOxUvFyMZGxsPHQce\/yD3IvMk6ybnKOMq3yzbLtsw1zLXNNc21zjbOts83z7jQOdC60TzRvtI\/0sHTRNPG1EnUy9VO1dHWVdbY11zX4Nhk2OjZbNnx2nba+9uA3AXcit0Q3ZbeHN6i3ynfr+A24L3hROHM4lPi2+Nj4+vkc+T85YTmDeaW5x\/nqegy6LzpRunQ6lvq5etw6\/vshu0R7ZzuKO6070DvzPBY8OXxcvH\/8ozzGfOn9DT0wvVQ9d72bfb794r4Gfio+Tj5x\/pX+uf7d\/wH\/Jj9Kf26\/kv+3P9t\/\/8=",
        "BTTAppleScriptRunInBackground" : false,
        "BTTAppleScriptString" : "on itemScript(itemUUID)\n        -- BTT doesn't monitor now playing state automatically, you'd need to at least once query the BTTCurrentlyPlaying variable - e.g. via Apple Script (or have one of the now playing widgets which are currently available for Touch Bar, Stream Deck and Notch Bar - I'll soon make the various widgets available to floating menus as well). https:\/\/community.folivora.ai\/t\/bug-missing-btt-playing-related-variables\/40039\/2?u=xidiot\n        tell application \"BetterTouchTool\"\n                get_number_variable \"BTTCurrentlyPlaying\"\n        end tell\n        tell application \"BetterTouchTool\"\n                set timestamp_new_song to get_string_variable \"custom_var_timestamp_new_song\"\n                set playing_not_playing to get_number_variable \"BTTCurrentlyPlaying\"\n                set duration_custom_var to get_number_variable \"BTTNowPlayingInfoDuration\"\n\n                -- Convert duration_custom_var to mins\n                set duration_min_custom_var to (duration_custom_var div minutes) as integer\n\n                -- Convert duration_min_custom_var to string and append \" min\"\n                set duration_min_str_custom_var to (duration_min_custom_var as string) & \" min\"\n\n                -- Change PlayPause based on the value of playing_not_playing\n                if playing_not_playing is 1 then\n                        set PlayPause to \" | Playing ▷ \"\n                else if playing_not_playing is 0 then\n                        set PlayPause to \" | Paused II \"\n                else\n                        set PlayPause to \"Unknown\" -- Optional: handle unexpected values\n                end if\n                -- actually this is title of video\n                set songTitle to get_string_variable \"BTTNowPlayingInfoTitle\"\n                -- this is channel name\n                set songArtist to get_string_variable \"BTTNowPlayingInfoArtist\"\n                set_persistent_string_variable \"custom_var_test_title\" to songTitle\n        end tell\n\n        set combinedInfo to timestamp_new_song & PlayPause & songArtist & \" | \" & songTitle & \" | \" & duration_min_str_custom_var\n\n        return combinedInfo\nend itemScript",
        "changedFile" : "9B1E0CFC-85C4-464A-951A-A6759106BB7E",
        "BTTScriptExternalPath" : "\/Users\/myuser\/Library\/CloudStorage\/OneDrive-\/Documents\/btt\/scripts\/now_playing_menu_item",
      "BTTMenuItemPaddingLeft" : 4,
      "BTTMenuOnlyCopyOpenCategories" : 0,
      "BTTMenuAttributedText" : "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red0\\green0\\blue0;}\n{\\*\\expandedcolortbl;;\\csgray\\c0;}\n\\pard\\tx560\\tx1120\\tx1680\\tx2240\\tx2800\\tx3360\\tx3920\\tx4480\\tx5040\\tx5600\\tx6160\\tx6720\\pardirnatural\\partightenfactor0\n\n\\f0\\fs22 \\cf2 New Item}",
      "BTTMenuItemPositioningMode" : 0,
      "BTTMenuItemMaxWidth" : 222,
      "BTTMenuTextMinimumScaleFactor" : 0.30000001192092896,
      "BTTMenuItemShadowRadius" : 0,
      "BTTLastChangeUUID" : "4849F217-542D-40E3-B76E-0AB2B5071735",
      "BTTMenuElementIdentifier" : "NowPlayingWorking",
      "BTTMenuItemY" : 2048,
    "BTTMenuName" : "NowPlayingWorking",
The Apple script itself is working, since if I execute it using "Run Script" from BTT - result is copied to the clipboard (which is what the action on right click should be doing)
@Andreas_Hegenberg , can this be the same like reported here - https://community.folivora.ai/t/disabling-floating-menu-dragging-prevents-standard-menu-items-from-registering-most-clicks/ ?
Yes that is very possible. Should be resolved in 5.683!
Maybe my case:
is for the same reasons?
