Hi Andreas,
When I press and hold the left mouse button on a floating menu item, even a slight movement of the mouse during the hold makes the long-press action fail. The normal single-click action fires instead.
This makes long press difficult to use unless I keep the mouse completely still. I would expect a little unintentional movement to be tolerated, rather than switching to the single-click action.
Is there a movement-tolerance setting for long press, or could this behavior be improved?
Affected input: mouse, left button. The exact affected BTT/macOS versions, latest-alpha test and restart check are not confirmed yet.
