Floating menu, scrolling order in horizontal.
Hello,
There is an issue with the scrolling order when using the floating menu in horizontal mode: the last elements appear first when the menu is triggered.
Thank you in advance for your help,
Best regards,
Did you maybe (accidentally) update the display order of some of the individual items?
Thank you for your reply, I have just checked and I have not changed that option for all the actions.
could you export your menu and send it to me? (andreas@folivora.ai)
I tried to reproduce but it seems to work fine here. Maybe some positioning setting?
