I've created a floating menu that has its "visibility toggled via action", and is set to "close after button press". I have a "Show floating menu" keyboard shortcut in BTT that I use to call the menu. The floating menu has a sub menu containing some "Paste Text" buttons.
When I enter my "Show floating menu" keyboard shortcut, open the submenu, and choose one of the "Paste Text" buttons, BTT correctly pastes the text and closes the menu. But, when I enter my "Show floating menu" keyboard shortcut again, it opens to the sub menu, not the top level menu. Is there a setting to have it always open at the top level menu?
(1) Suggest sub-menu of floating menu can define it's own min width/height normal/hover.
(2) A dummy seperator menu item for items on menu and sub-menu
Thank you for listening.
Thank you so much for this. This is just the feature I have been looking for and after paying for BTT for almost 15 years, this is the first time I've created an account to say thank you.
