Floating Menu not working on Mobile
Floating menu will not work reliably on Mobile iOS app, works fine on my mac except the back button item always goes back to the "homepage" if you will. On mobile it keeps attempting to reconnect and slows my macbook pro m1 down to an almost complete halt, can't click anywhere reliably etc. Only fixed by closing Mobile app connected.
Affected input device
Mobile app iOS and floating menu back button item on macos (fine on mobile when it works)
  • Type of Mac: M1 Macbook Pro 2020 16gb RAM
  • macOS version: Tahoe 26.6.2
  • BetterTouchTool version: 6.842 initially and then updated to alpha 6.843 and same issue on both.
could you share a menu that doesn’t work for you? (either attach here or send to andreas@folivora.ai)
GM Menun.bttpreset (7.8 MB)
Yep! I can share the menu. I'll send you a copy of the problematic Floating Menu.
One additional thing I discovered after posting: if I disconnect Wi-Fi on the iPhone, BTT Mobile immediately connects via P2P and the menu starts working. If I then reconnect Wi-Fi, it continues working normally. So it seems like the Mobile connection gets stuck/reconnects endlessly when initially connecting over Wi-Fi.
