Hi, I'm using BTT ver. 4.375 and the floating menu fails to open at mouse position upon modifier-based activation despite setting it to do so in the "Position On Screen" setting in the Floating Menu Configuration.
Here's a quick screen recording showing the issue:
You can see that I have set holding the CTRL + OPT + CMD keys to activate the floating menu at mouse position, and yet when I hold those keys down, the floating menu doesn't open at the mouse position.
Help would be appreciated and I'm happy to provide more info as needed! Thanks in advance.
