- I set up floating menu to popup at mouse cursor position, whenever I press fn key.
- It works fine, until you switch focus to another window of another app. The first time I trigger the key, the menu popup as usual, but in seemingly random place on screen!
- The popup appear at correct position after the 2nd keypress and later though (until you switch app again)
Appreciate your help. Thank you!
- Type of Mac: Macbook Pro M1 Pro
- macOS version: Sequoia 15.2 (24C101)
- BetterTouchTool version: 5.00 (2025010701)
