Floating menu like Logi Actions Ring
Ah, do you still have them in the top level group? If so you need to delete them from there (have a look at the recently used section to see where they are triggered from)
Can you take a look at the 2 filter screengrabs above. I think the true and false are wrong as it gives false while in BTT. See also following as it shows the menu for =! BTT while in BTT:
Also not sure why the Signal.app part is in the filter condition:
appName != "BetterTouchTool
BetterTouchTool
BetterTouchTool
BetterTouchTool
BetterTouchTool
/Applications/Signal.app/Contents/Resources"
Looks like you copied multiple things into the condition field but you don't see it because it only shows one line. Select the whole content of the field (cmd+a) and delete it, then enter BetterTouchTool again
Ok, filter issue was idd due to copy/paste, but still it gives true for =! BTT while in BTT
and was now automatically updated to false:
and after restart BTT back to TRUE:
Do you have that option enabled in BTT's View menu?
yes it is:
afbeelding
Ah! Disabling that should resolve your issue.
Yes that solved all the issues. Tricky to have that keycombo for a function with such a impact on the app. What is it actually for as there is no info on the website:
Emulate Selected App as Active
It makes BTT think the app that is currently selected in the left sidebar is active. Can be helpful for configuring app specific stuff (e.g. a floating menu that is only active in finder or a touch bar configuration that is different for a specific app).
Suggestion:
Stumbled upon: Gesture is not working when a Visual Seperator
afbeelding
is added:
afbeelding
True, fixed in v4.790!
Hey Andreas, Is it possible to trigger different menu's depending on the swipe length? Would be nice to be able to short swipe 3 fingers down for an action menu and longer swipe for apps switch menu
this is not possible right now as BTT's algorithms don't track the length.
Maybe a click-swipe down could work?
Thx, I'll give it a go
Difficult (say impossible) to use, as soon as you want to move the mouse to a menu option, it triggers the center menu item(I think due to hoover focus release)
  1. Dark theme issue:
  2. Would be convinient if other in use gestures also be shown/marked. Also when looking for a gesture for a new trigger.
    BetterTouchTool-407x493
Menu update after altering menu item visibility does not work properly v. 4.859. It updates after restart of BetterTouchTool.
ps. see also prev. post above regarding dark theme.
Thx!
